CelevGadol
Apr 23, 2022Follower
Smart TV and Unmanaged Switch GS305v3
Hi I have recently purchased a couple of GS305v3 unmanaged switches. I have also wired some ports from near my hub to the living room. I use the ports to connect my laptop, games console and TV. The...
Apr 24, 2022Guru - Experienced User
the gs305v3 is a simple unmanaged switch. It really has nothing in it to block/obstruct the connection.
Did you re-run the network setup on the tv when you connected it?
Make sure to uses a good quality cat 6 cable. Some devices are more sensitive to sketchy cables
