MarvinGS116
Jan 11, 2025Tutor
Streamer app not recognising streamers on wired network using GS116v2 but does when using GS108v4
Happy New Year I have a question about communication between multiple streamers (Linn DSM’s) , Netgear switches , a Talktalk router and an IPhone iPhone 13 ios18 Talktalk Sagecom 5364 router with...
Jan 12, 2025Guru - Experienced User
You sure you have a GS116v2 or do you have a GS116Ev2?
The 116v2 is a non managed switch so no web page access and is just pass thru of all data traffic.
The 116Ev2 is a smart switch so it has a management web page and some user configuration options.
Be sure to check cableing. CAT6 UTP is recommended.
- MarvinGS116Jan 12, 2025TutorHi
Thanks for that
It is GS116v2 ( no E or other letters)
I have tried switching everything off and on in the suggested order
Why does the new one work and the older one doesn’t?
Cheers- FURRYe38Jan 12, 2025Guru - Experienced User
So when using the 116 and 108 switches daisy chained works?
Using them separately, doesn't work?
The current set up which works is
Internet - router&modem with 4 rj45 ports, using port 1 to GS116 and port 2 to GS108.
The GS116 is connected to desktop TV printer storage and this all works
The GS108 is only connected to the Linn streamers
When the streamers are connected to the router/modem they work
When the streamers are connected to the GS116 the Linn app on my phone can’t find them
Someone suggested it is. DHCP issue??
Thanks for helping
