MarvinGS116
Jan 11, 2025Tutor
Streamer app not recognising streamers on wired network using GS116v2 but does when using GS108v4
Happy New Year I have a question about communication between multiple streamers (Linn DSM’s) , Netgear switches , a Talktalk router and an IPhone iPhone 13 ios18 Talktalk Sagecom 5364 router with...
Jan 12, 2025Guru - Experienced User
You sure you have a GS116v2 or do you have a GS116Ev2?
The 116v2 is a non managed switch so no web page access and is just pass thru of all data traffic.
The 116Ev2 is a smart switch so it has a management web page and some user configuration options.
Be sure to check cableing. CAT6 UTP is recommended.
MarvinGS116
Jan 12, 2025Tutor
Hi
Thanks for that
It is GS116v2 ( no E or other letters)
I have tried switching everything off and on in the suggested order
Why does the new one work and the older one doesn’t?
Cheers
Thanks for that
Cheers
- FURRYe38Jan 12, 2025Guru - Experienced User
So when using the 116 and 108 switches daisy chained works?
Using them separately, doesn't work?
- MarvinGS116Jan 12, 2025TutorHi
The current set up which works is
Internet - router&modem with 4 rj45 ports, using port 1 to GS116 and port 2 to GS108.
The GS116 is connected to desktop TV printer storage and this all works
The GS108 is only connected to the Linn streamers
When the streamers are connected to the router/modem they work
When the streamers are connected to the GS116 the Linn app on my phone can’t find them
Someone suggested it is. DHCP issue??
Thanks for helping - MarvinGS116Jan 17, 2025TutorHi
I have at last had a chance to test
When the chain is router Gs108v4 (with the music streamers) into GS116v2(with everything else ( access point, Epson printer combo, Sony TV, Apple TV, Panasonic TV, Desk top*2, Xbox), my phone streamer app can find the streamers.
When the chain is router to GS116 to GS108 my streamer app cannot find the streamers
Any thoughts?
Cheers- FURRYe38Jan 17, 2025Guru - Experienced User
Maybe some daisy chaining issue that the streamers or there app doesn't like this configuration GS116 to GS108.
I think you'll need to keep everything at the 1st switch. Seems like if you use the 16 port switch, would be best and not use the 8 port switch. Something odd that these two daisy chained is not passing the streaming app data properly.
Or keep the Gs108v4 (with the music streamers) into GS116v2.
- MarvinGS116Jan 19, 2025TutorHi
Using the GS108v4 on its own works
Using the GS116v2 on its own with the streamers wired to it does not
The streamers plugged into the router allows the streamer phone app to find the streamers
Thanks
