ElitePCgamer
Jun 16, 2016Aspirant
Switch added, limited connection on 1 device
I have recently added a ProSafe GS108 switch to my home network. My wired pc's are able to access the internet but my media streaming Android box has very limited connection meaning I can do a speed ...
- Jun 20, 2016
It was user error on my side
JohnRo
Jun 17, 2016NETGEAR Employee Retired
Hello ElitePCgamer,
Welcome to the community!
The GS108 is only a passthrough switch and does not have any QoS settings so I don't think it has anything to do with the limited connection on the Android Box. Did you test if you get the same behavior if the Android Box is connected directly to the router?
Thanks,
ElitePCgamer
Jun 20, 2016Aspirant
- JohnRoJun 21, 2016NETGEAR Employee Retired
Hello ElitePCgamer,
Thank you for the clarification. If this post had helped you in any way, please mark it as "Accept as Solution".
Have a great day!
Thanks,
