nk4
May 04, 2020Aspirant
Switch Daisy Chain (No Internet)
I have the attached network topology. I have an issue daisy-chaining two NETGEAR switches; I cannot get any internet in my office. Internet on other devices attached to the GS105 seem fine. Any ide...
- May 04, 2020
Or even
virgin modem-------google router-------gs105------skyq
GS105
Reason why is the virgin hub in modem mode only gives out 1 public ip address. The router uses that and then assigns multiple private ip addresses to specific devices. So in modem only mode, it needs to go modem------router----switch/devices.
May 04, 2020Guru - Experienced User
Try running it like this:
virgin modem-------->google wifi------->skyq/etc
GS105-------------->gs105
- plemansMay 04, 2020Guru - Experienced User
Or even
GS105
- nk4May 04, 2020Aspirant
Thanks for the reply. That looks to have worked, thank you.
