JimTurkey
Sep 27, 2021Guide
Switches for Dummies
In our bedroom, wi-fi is the weakest in the house. Luckily, we have a hard-wired ethernet port behind the TV that I was thinking we could hook up. However, that is only 1 port and I'd like to hook up...
- Sep 27, 2021
A simple unmanaged switch is a great plan.
Pretty much plug and play.
I'd pay the little extra to get a gigabit one.
usually you can get a 5-8 port gigabit for around that $20-30
JimTurkey
Sep 27, 2021Guide
Which one would you recommend?
We have 1000 Mbps internet.
Sep 27, 2021Guru - Experienced User
Pretty much all unmanaged gigabit switches should do the job for you. Pick one that has the ports you need and the looks you want.
- JimTurkeySep 27, 2021Guide
What is the difference between the Netgear GS105 and GS305??
Thanks!
- JimTurkeySep 27, 2021Guidecan i use any unmanaged switch for my orbi rbk752 in AP Mode?
- plemansSep 28, 2021Guru - Experienced User
Thanks!
Not a whole lot. One is business class and the other is consumer. Theres some cosmetic differences based on versions (v1-v5)
From the suppport site the GS105 is lifetime warranty and the GS305 is 3 year.
Theoretically you should be able to use any unmanaged switch. Some have had issues with green features on the Orbi AC's. I didn't have a single issue and I've tried several unmanaged switches and a managed switch. And thats been tested on the AC versions and the SXK30 series.
