tonynsx
Dec 22, 2022Luminary
Dummy (unmanaged) switch for VoIP phone and computer
Just to make sure, if I want to connect a VoIP phone and computer, I need a PoE Manged switch correct? Because dummy (unmanaged) switch wouldn't be able to do both voice VLAN and computer VLAN?
VoIP phone connects to managed switch with voice VLAN as Trunk and computer VLAN as Untagged. Then computer connects to the back of the VoIP phone. This is the only and recommended way right?
If I replace the managed switch with a dummy switch what would happen?
PoE is required if the test VoIP device needs to be PoE powered and has no power input connection available.
To configure a simple VLAN deployment with two VLANs you need at least a switch with the ability to define two VLANs, and define the required port config in tagged or untagged form for your test set-up. An unmanaged switch isn't sufficient.
