tonynsx
Dec 22, 2022Luminary
Dummy (unmanaged) switch for VoIP phone and computer
Just to make sure, if I want to connect a VoIP phone and computer, I need a PoE Manged switch correct? Because dummy (unmanaged) switch wouldn't be able to do both voice VLAN and computer VLAN? ...
- Dec 22, 2022
PoE is required if the test VoIP device needs to be PoE powered and has no power input connection available.
To configure a simple VLAN deployment with two VLANs you need at least a switch with the ability to define two VLANs, and define the required port config in tagged or untagged form for your test set-up. An unmanaged switch isn't sufficient.
schumaku
Dec 22, 2022Guru - Experienced User
