Uslzr
Sep 08, 2019Aspirant
Trouble with GS116
I have a NETGEAR DOCSI 3.1 modem. Model CM1200. We purchased the Arris AX11000 router for its WIFI capability. The two work fine together, but when I plug my NETGEAR GS116 switch it does not work. Any...
- Sep 08, 2019Thank you for the response, we tried doing a complete reboot and it started working. Thank you for your time
schumaku
Sep 08, 2019Guru - Experienced User
The GS116 is a non-managed switch which should be working with easy for adding more ports to your Arris router or on one of it's satellites.
Tell us more on how/where this GS116 is connected to this set-up with the Netgear cable modem and the Aris WiFi system.
Uslzr
