Retired_Member's avatar
Retired_Member
Mar 18, 2021
Unable to access Internet from gs105 unmanaged switch
Basically the title. Purchased the switch with the intention of using it to have access to more internet-capable ports in my room, so that I wouldn't have to contantly swap the cable from device to d...
  • JohnC_V's avatar
    Mar 24, 2021
    @rapidlypen,
    Welcome to our community! Smiley Happy
    It seems that you are having issues with adding the switch to your network. May I know if you already tried using your PC to directly connect it to the patch panel? Does it receive an IP address? This switch is just a plug-and-play unit. We can only isolate cases for us to identify the problem.
    John
    NETGEAR Community Team
ProSupport for Business
