ethernut
Oct 16, 2021Aspirant
Using several POE adaptors downstream of GS105 switch. Is it OK?
I have a GS105 switch that I intend to use in a 4G Internet solution in a remote area. I have an antenna with a built in that modem and router that outputs via simple ethernet cableThe anenna is po...
- Oct 16, 2021
That's more a question you should raise with the makers of these crazy proprietary "PoE" adapters and hardware.
The DC path should be isolated towards to the switch, and only provide power to the powered device.
Nothing the switch can and must do against this here.
ethernut
schumaku
Oct 16, 2021Guru - Experienced User
