NBB1
Oct 04, 2022Aspirant
What size grounding screws are needed for the chassis ground hole on GS110MX unmanaged switch?
I see there's a hole for the grounding the chassis on the metal housing of the GS110MX 8-port unmanaged switch, but I can't find out the thread size of the hole. It seems like M4 is a pretty standar...
- Oct 04, 2022
A hole to properly thread (or force in) an M4 screw would require a drill diameter of 3.3 mm.
The small Netgear switches I have at hand - leaving alone the additional requirements of patch cables with shielded/grounded patch cables or installations - measure to about 3.0 mm, so it's most likely M3. Well, at least M3 nuts fit well.
schumaku
Oct 04, 2022Guru - Experienced User
NBB1
Oct 05, 2022Aspirant
Thanks, schumaku! So it appears Netgear uses M3 screws for their chassis grounds..interesting. Sounds like I might be able to squeak by with a ring terminal meant for a #4 stud.
Separate-but-related question: what is that funny-shaped metal piece between the screw and washer in your first image? Is that a Netgear-specific grounding screw assembly or something?
Thanks again for the assistance, schumaku!
