mmitsch
Mar 19, 2018Tutor
What switch to buy?
I have a Netgear R8000 Nighthawk X6 AC3200 Tri-Band WiFi Wireless Router and a Netgear CM700-100NAS Cable Modem. An insatller is setting up my home network and he said he needs me to get a 16 port s...
mmitsch
Mar 26, 2018Tutor
I bought the GS116NA but think maybe I should take back & get the 316 based on your advice.
Thanks for the help & let me know what you think.
DaneA
Mar 27, 2018NETGEAR Employee Retired
Having the GS116 switch in your existing network is just alright. :)
Reagrds,
DaneA
NETGEAR Community Team
- mmitschMar 27, 2018Tutor
You mean by just alright that it'll be ok? The insatller guy put it it but, if I should switch, I will.
And thanks for the advice!
Mike
