Homeuser66's avatar
Nov 25, 2015
What's the proper set up for my Netgear JGS524
Hi, I am new to the networking aspect of computers. I have an:
AT&T Gateway (5031nv)
Asus Router (RT-AC68U)
DirecTV GenieGo
WD 4TB MY Cloud
My current set up is From AT&T gateway I have 1 line feeding into my Netgear Switch, and another line going to my ASUS Router which has my DirecTV GenieGo hooked up to . Then I have everything else hooked up into the Netgear.
My question is, should I just have everything go into the Netgear, and then everything would be on the same network? I only have 1 issue right now and I did a work around for it, but I had my wireless printer working before for all PC's and devices, now it won't. I had to revamp my room and unhooked everything and don't remember how I origianlly had it set up, but this is kinda working for me other than the printer part.
If you need a diagram, I'll draw one if need be, but be warned, I'm not an artist!
Thanks in advance!
  • DaneA's avatar
    DaneA
    Nov 26, 2015
    Hi Homeuser66,
    Here is what BrianL is trying to tell you.  Kindly read the following below:
    A.  If ever the AT&T gateway is a combination of modem and router, then configure the AT&T Gateway as a modem-only device.  Then connect the Asus router directly to the AT&T Gateway.  This will make the Asus router as the main router.  Then connect the JGS524 switch directly to the Asus router to extend the local network.  Refer to the image below:
    B. If ever the AT&T gateway is a combination of modem and router then you could just remove the Asus router from the network setup.  This will make the AT&T gateway the main router.  Then connect the JGS524 switch directly to the AT&T gateway to extend your local network.  Refer to the image below:
    C. From scenario B, if ever the AT&T gateway is a combination of modem and router then you could just remove the Asus router from the network setup.  This will make the AT&T gateway the main router.  Then connect the JGS524 switch directly to the AT&T gateway to extend your local network.  For wireless access to the internet, you may configure the Asus router as an Access Point then connect it to the JGS524 switch.  Refer to the image below:
    Hope these helps.
    DaneA
    NETGEAR Community Team
  • Hey,
    Diagram would help. You have the printer and the other devcies connected to an access point right?
    • JohnRo's avatar
      JohnRo
      NETGEAR Employee Retired
      Hello Homeuser66,
      Welcome to the community!
      In addition to the diagram, it would be best if you can give us your goals in changing your working network. Your setup right now looks good since you have the ASUS router is separated, so if ever the JGS524 goes down you will still have the network on the ASUS working. Are you looking to get the best bandwidth usage? Network performance?
      Looking forward to your response.
      Thanks,
      • Homeuser66's avatar
        Homeuser66
        Guide
        Thanks for the quick replies!
        I'm uploading my diagram. I'm not sure as to why, my printer worked flawlessly wirelessly and now it won't. I think I have to plug my Asus Router into the Switch, but don't understand it all. I have to have my GenieGo (for DirecTV) hooked up to my Asus which does my 2.5G and 5G wireless networks. All my DirecTV boxes are all wirelsss and this box has to be on the same network. I also tried to hook my printer to the switch, but it wasn't found. Ohh, and I'm running Windows 10, 7 on multiple PC's and only my Wireless Windows 10 Laptop saw my printer recently.
  • Thanks Brian,
    I'm thinking :
    Internet to AT&T
    AT&T to Asus
    NETGEAR and GenieGo into Asus
    Everything else into switch?
    If I understood you correctly?
    • DaneA's avatar
      DaneA
      Hi Homeuser66,
      Hope these helps.
      DaneA
      • This is perfect! I was trying to understand this whole networking thing. I only use the Asus Router for the Wifi as the AT&T 2.5G interfered with my Logitech G930 wireless headset (Which I no longer have). The whole configuring the AT&T Gateway as a modem only device I did a few months ago and had issues making long distance phone calls, so I set it back to default and just turned off the wifi on it. Bought this Switch with the impression that it pretty much adds ports to whatever I plug it into (example: Asus has 4 ports, plugging this into it would give me 27 ports on the Asus). I'll play around with what you just posted!
        Thanks again!
ProSupport for Business
