mmxg's avatar
mmxg
Which SWITCH is newer?
Looking for help on which is the most current / recent manufactured switch - is GS205 newer or older than GS605? What is the difference between the different GS605 versions - is functionality / compa...
  • mmxg's avatar
    mmxg
    Oct 10, 2018
    thank you.
    So just to clarify my question overall, is there any real difference in functionality between GS605 and GS205. Are the different versions hardware parts or software / firmware updates?
ProSupport for Business
