Adenmara
Nov 06, 2023Tutor
XS508M connection issues
Hello, ever since I have my XS508M in use (since a bit over a year now), some devices have problems correctly connecting to the network while plugged into the XS508M Switch. Problems I have enco...
schumaku
Nov 06, 2023Guru - Experienced User
Adenmara wrote:I also tried getting hardware support through the Netgear website, but I only get an error stating "somethingWentWrong'".
Can't help on this - appears to be some Netgear IT issue.
Adenmara wrote:
4. Arduino Uno with Ethernet Shield (WS5100), which is connected through a 1Gb switch to the Netgear XS508M sometimes needs a few times of plugging out and in until it connects to the network..
This is a very basic 10 Mb/s Ethernet resp. FastEthernet 100Mb device only. An intermediate switch might magically "fix" the link issue problem.
Adenmara wrote:
3. Another PC (Windows 10, 2.5 Gb) sometimes doesn't connect to the network correctly and the network card needs to be reset or plugged out and in a few times until it works. Windows troubleshooting does help sometimes (it also rests the network adapter) and says the problem was "Ethernet has no valid IP configuration"..
2.5Gb/s network adapter, type/chipset model, driver version?
Adenmara wrote:
2. One PC (Windows 10, 1Gb) connected to the Netgear XS508M gets packetloss and sometimes doesn't corretly connect to the network. Connecting the PC directly to the Router fixes the issue..
1 Gb/s network adapter, type/chipset model, driver version?
Adenmara wrote:
1. Connecting my main router/modem (Fritzbox 6591 Cable, 1Gb, DHCP) directly to the XS508M leads to packetloss from all devices to the router&internet. I've fixed this issue by connecting the router through a Zyxel 1Gb switch to the Netgear XS508M.
Energy saving mode on the Fritz LAN port active?
Adenmara
Nov 07, 2023Tutor
Thanks for your reply.
schumaku wrote:This is a very basic 10 Mb/s Ethernet resp. FastEthernet 100Mb device only. An intermediate switch might magically "fix" the link issue problem.
The Switch I'm using in between is a Zyxel GS-105B v3, which supports 1Gb and 100 Mb. But I can try getting a 100 Mb only switch and try that.
schumaku wrote:2.5Gb/s network adapter, type/chipset model, driver version?
Realtek® 8125B 2.5G LAN controller, Driver: 10.59.425.2022
schumaku wrote:1 Gb/s network adapter, type/chipset model, driver version?
Intel I218-V Gigabit LAN controller, Driver: 12.15.22.3
schumaku wrote:Energy saving mode on the Fritz LAN port active?
No, all ports are on power mode (1Gb), and the general energy savings mode is turned off.
