Adenmara
Nov 06, 2023Tutor
XS508M connection issues
Hello, ever since I have my XS508M in use (since a bit over a year now), some devices have problems correctly connecting to the network while plugged into the XS508M Switch. Problems I have enco...
schumaku
Nov 06, 2023Guru - Experienced User
One more question: Operating Jumbo Frames?
Adenmara
Nov 07, 2023Tutor
schumaku wrote:One more question: Operating Jumbo Frames?
I didn't change any settings on any device regarding Jumbo Frames, I would guess this is disabled then? I don't know much about that.
It is disabled on the Windows PCs in the network adapter settings.
Edit, since the forum seems to like, not sending my posts through... here is the first reply I sent:
schumaku wrote:This is a very basic 10 Mb/s Ethernet resp. FastEthernet 100Mb device only. An intermediate switch might magically "fix" the link issue problem.
The Switch I'm using in between is a Zyxel GS-105B v3, which supports 1Gb and 100 Mb. But I can try getting a 100 Mb only switch and try that.
schumaku wrote:2.5Gb/s network adapter, type/chipset model, driver version?
Realtek® 8125B 2.5G LAN controller, Driver: 10.59.425.2022
schumaku wrote:1 Gb/s network adapter, type/chipset model, driver version?
Intel I218-V Gigabit LAN controller, Driver: 12.15.22.3
schumaku wrote:Energy saving mode on the Fritz LAN port active?
No, all ports are on power mode (1Gb), and the general energy savings mode is turned off.
