Victorgo's avatar
Victorgo
XS708E running super hot and hangs after about 2 to 3 weeks of usage
Hi guys,
I installed the XS708E at home for my home enterntain system. I reaised that the switch becomes extremely hot after a while. The switch is installed in an open area where it is well ventilated. I realised that the perfomance of the switch slows down over time and eventually hangs. I will then need to turn the switch off for 15min to allow it to cool down and then turn it on again. I realised I need to do this once every 2 to 3 weeks.
Is this something common?
  • Thanks for the update. I will follow up with Amazon.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Looking up that unit, it appears to be a unit that was returned to the reseller soon after it was purchased. You should follow up with the reseller on this.
    • Victorgo's avatar
      Victorgo
ProSupport for Business
