badams
May 31, 2016Aspirant
2 Ports on the same VLAN
Hello, I am trying to get 2 ports of our firewall to be on the same network/VLAN so they can talk to eachother. Basically, one port currently has our AP and I would like to connect our printer to th...
- Jun 01, 2016
Hello, and thank you for the response. I found out the problem, under port membership only port one was checked. After checking the other ports we're green across the board. Thanks again!
-Brian A
badams
Jun 01, 2016Aspirant
-Brian A
JohnRo
Jun 01, 2016NETGEAR Employee Retired
Hello badams,
Nice to know you go it working! If my previous response did help you with the solution we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
