joakimcarlsten
Jun 03, 2016Aspirant
Accessing specific VLAN after VPN
Hi, I have a SRX5308 and have set up a PPTP VPN server. I have four VLANS configured, say: 10.0.A.0/24 10.0.B.0/24 10.0.C.0/24 10.0.D.0/24 and the PPTP server configuration is to give VPN...
- Jun 05, 2016Ah yeah that would explain it :)
IPSec is very easy to set up, don't be scared by the many settings - you won't really need to do much with then. As for the fqdn you'll set that in the client you're connecting from so it doesn't really matter from where.
With the Netgear IPSec client it's really easy and the support team can help you get it working.. There's a 30 day free trial so you can test it.
There's also a free third party client called Shrewsoft, it's pretty easy to set up too but some features seem hard to get working, I'd recommend the official Netgear client but if you want to give shrew a go I did write a small guide a while back for a very basic client-to-box setup with it;
http://www.hexnet.se/srx5308-ipsec-vpn-with-shrew-soft/
I think there's been some issues with shrew and certain firmware though, at some point you could only do mode config (which is what shrew's own manual shows) but I can't get that working with the srx5308's latest firmware.. However I didn't spend too much time on it, I'm sure it can be figured out.
joakimcarlsten
Jun 06, 2016Aspirant
Ok, thanks.
One last question:
Is there any way of using IPsec and not having to use any third party software but instead use the built in vpn software in OSX and win 10?
DaneA
Jun 06, 2016NETGEAR Employee Retired
Hi joakimcarlsten,
So far, I have not found any articles online about using the built-in VPN client of OS X and Windows 10. However, most VPN users would recommend IPSecuritas and VPNtracker to be used with OS X. Let me share these articles below as references:
Mac OS X VPN Client install with ProSAFE VPN Firewall/Router
MAC VPN client vendors for ProSECURE UTM & ProSAFE Routers
IP Securitas Os X – Netgear FVS336G VPN Settings
NETGEAR - IPSEC VPN Client - MAC & Iphone & Ipad - (Client 2 Box)
http://www.vpntracker.com/us/vendor/6/netgear-mac-vpn-client.html
Furthermore, read this forum link from Apple Support Communities below:
https://discussions.apple.com/thread/1351175?tstart=0
Hope it helps :)
DaneA
NETGEAR Community Team
- joakimcarlstenJun 06, 2016Aspirant
Ok,
thanks guys for the help and the information.
Kind regards
Joakim
