Augello
Aug 25, 2017Tutor
Basic VPN client setup
I have 5 users that will access our network through a VPN Tunnel. Is it best to use a single VPN Tunnel Setup on the Router for all 5 user connections or is it better to create a VPN Tunnel Configura...
DaneA
Aug 27, 2017NETGEAR Employee Retired
Hi Augello,
I suggest that you create one VPN/IKE Policy using the VPN Wizard. This will be enough for the 5 VPN clients.
Kindly access the articles below as your reference guide:
ProSAFE VPN Client: Client to Box Configuration
Configure an IPv4 IPSec VPN Connection between a Gateway and a Client - read pages 8-15
DaneA
NETGEAR Community Team
