Augello
Aug 25, 2017Tutor
Basic VPN client setup
I have 5 users that will access our network through a VPN Tunnel. Is it best to use a single VPN Tunnel Setup on the Router for all 5 user connections or is it better to create a VPN Tunnel Configura...
DaneA
Aug 30, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
