SYSguy
Oct 30, 2020Aspirant
Best way to disable VPN access by schedule
What is the best way to disable all inbound access through VPN say for a period of Midnight to 8am. I tried to setting a schedule and a firewall rule, but it blocks all traffic including LAN. I j...
DaneA
Nov 09, 2020NETGEAR Employee Retired
As far as I've checked the SRX5308 user manual here, there is no option to disable (by schedule) all inbound access through VPN.
DaneA
NETGEAR Community Team
- SYSguyNov 11, 2020Aspirant
Dane, Thanks for the reply.
I'm stuck supporting this old box but thought I had a way. I tried the following,
but ended up blocking all traffic.
On Page 190 you can create schedules, see attached.
On Page 151 you can create rules, and specify a schedule, see attached.
Sure seems like there is a way.
As always, I appreciate your help.
CC
