SYSguy
Oct 30, 2020Aspirant
Best way to disable VPN access by schedule
What is the best way to disable all inbound access through VPN say for a period of Midnight to 8am. I tried to setting a schedule and a firewall rule, but it blocks all traffic including LAN. I j...
DaneA
Nov 09, 2020NETGEAR Employee Retired
As far as I've checked the SRX5308 user manual here, there is no option to disable (by schedule) all inbound access through VPN.
DaneA
NETGEAR Community Team
SYSguy
Nov 11, 2020Aspirant
Dane, Thanks for the reply.
I'm stuck supporting this old box but thought I had a way. I tried the following,
but ended up blocking all traffic.
On Page 190 you can create schedules, see attached.
On Page 151 you can create rules, and specify a schedule, see attached.
Sure seems like there is a way.
As always, I appreciate your help.
CC
- SYSguyNov 11, 2020Aspirant
Well, adding pictures didn't work.
Maybe this?
- DaneANov 16, 2020NETGEAR Employee Retired
The Schedule you are pertaining to as described in the images posted is for the LAN WAN Inbound Rule and its not for VPN access.
DaneA
NETGEAR Community Team- SYSguyNov 16, 2020Aspirant
Dane,
Thanks for taking the time to help.
I was hoping these rules applied to all WAN access, including VPN.
Oh well, helps my argument for the owner to upgrade, at last!
Thanks again, appreciate it.
CC
