SYSguy's avatar
SYSguy
Best way to disable VPN access by schedule
What is the best way to disable all inbound access through VPN say for a period of Midnight to 8am.   I tried to setting a schedule and a firewall rule, but it blocks all traffic including LAN. I j...
  • DaneA's avatar
    DaneA
    Nov 16, 2020
    SYSguy,
    The Schedule you are pertaining to as described in the images posted is for the LAN WAN Inbound Rule and its not for VPN access.
    DaneA
    NETGEAR Community Team
ProSupport for Business
