Davoxx
May 03, 2021Aspirant
BR200 IPSEC VPN behind my ISP Router
Hi, I have a BR200 router that i recently bought. Is it possible to do a IPsec VPN on the BR200 to another Vendor VPN device. Also Is it possible for a VPN connection to be established with the BR2...
JohnC_V
May 05, 2021NETGEAR Employee Retired
Welcome to our community! :)
So you want to set up a site-to-site VPN using the BR200 to another VPN router. It should work just fine without any issues as long as the credentials are correct but it will not work if the WAN interface of the BR200 has a private IP address. You may need to set the ISP router to bridge mode in order for the IPsec VPN to work and receive a public IP on the WAN of the BR200.
John
NETGEAR Community Team
- schumakuMay 05, 2021Guru - Experienced User
Thats's the price for not implementing L2TP for site-to-site and client IPsec connections on BR200/500. A long way to go to a Business Router product....
- DavoxxMay 06, 2021Aspirant
Thanks for your assistance.
Can BR200 device admin page be reached or configured using a public IP address ?
