mladach
Jan 28, 2019Follower
BR500 - Management Access from internal VLAN
Insight BR500 VPN Firewall Router
We have a BR500 router and GC728P switch that are set up with Insight. Some of the BR500 features are not available via Insight, so we connect directly to the ...
MrJoshW
Jan 28, 2019NETGEAR Employee Retired
Hello,
Management of the BR500 can only be done through VLAN 1 currently. This has been brought up by engineering on a possible solution in a later update to allow VLAN routing to the admin portal of the BR500.
