warsawtech
Apr 11, 2019Tutor
BR500 high CPU usage and default to factory settings on reboot
BR500 2x in a 10 day period the CPU usage pegged at 98%. The router showed a message that router should be rebooted. When I rebooted it from Insight web page it didn't come back online. Drove to clie...
- May 01, 2019
Hi
yes high cpu alert, although saying at 50%
loaded new firmware and holding so far..
thank you very much
DaneA
Apr 15, 2019NETGEAR Employee Retired
Hi warsawtech,
I found out from the NETGEAR Support Team that you have opened a support ticket (case # 41163704) regarding your concern described on your post. The NETGEAR Support expert assigned on your support ticket sent you a follow-up e-mail on how to get the BR500 Logs and on how to attach it on your support ticket. The BR500 Logs is required so that your support ticket can be escalated to the engineering team for further investigation.
DaneA
NETGEAR Community Team
- warsawtechApr 16, 2019Tutor
Problem is my support Case #: 41163704 is not showing up in My Support. So I can't upload the logs
- MrJoshWApr 16, 2019NETGEAR Employee Retired
Hello,
I have taken ownership of case 41163704 and will send you a private message to verify contact information and collect the logs for review.
- DasTylerApr 29, 2019TutorHi
Having the same problem. Any resolution to this? Have two BR500s doing the same thing. They have rebooted themselves and always go back to factory settings. Getting very tired of having to go to site and reload backup configuration files.- warsawtechApr 29, 2019Tutor
DasTyler wrote:
Hi
Having the same problem. Any resolution to this? Have two BR500s doing the same thing. They have rebooted themselves and always go back to factory settings. Getting very tired of having to go to site and reload backup configuration files.Go to here and upload the stable release of this firmware and it seems to fix the issue:
At least I'm not the only one having the issue. Did you happen to notice if you had high CPU usage??
- DasTylerMay 01, 2019Tutor
Hi
thank you very much
