warsawtech
Apr 11, 2019Tutor
BR500 high CPU usage and default to factory settings on reboot
BR500 2x in a 10 day period the CPU usage pegged at 98%. The router showed a message that router should be rebooted. When I rebooted it from Insight web page it didn't come back online. Drove to clie...
- May 01, 2019
Hi
yes high cpu alert, although saying at 50%
loaded new firmware and holding so far..
thank you very much
warsawtech
Apr 29, 2019Tutor
DasTyler wrote:
Hi
Having the same problem. Any resolution to this? Have two BR500s doing the same thing. They have rebooted themselves and always go back to factory settings. Getting very tired of having to go to site and reload backup configuration files.Go to here and upload the stable release of this firmware and it seems to fix the issue:
At least I'm not the only one having the issue. Did you happen to notice if you had high CPU usage??
DasTyler
May 01, 2019Tutor
Hi
thank you very much
