BretD
Oct 24, 2019Administrator
BR500 VPN Currently Experiencing Intermittent Connectivity Issues - Reply Thread
Update Oct 30, 2019
Dear NETGEAR BR500 customers,
Over the past two weeks we have experienced extreme instability with our VPN cloud ecosystem. We believe it is due to the scale of custo...
eremo
Jun 05, 2020Guide
Rebooting has never fixed the VPN connection for me. I no longer try rebooting when the VPN goes down. When the VPN comes back up again, it does so on it's own without me rebooting.
NathenB
Jun 05, 2020Apprentice
I agree that this is typically how it works for me as well. I am just trying to provide info, in the event that tech support may be watching.
- warsawtechJun 06, 2020Tutor
Things still offline this morning.
Status is also still listed as performance issues on https://status.netgear.com/insight
Trying to use Insight VPN Client gives me this today:
- tetrawestJun 06, 2020Apprentice
My site-site Insight VPN was off-line for at least 12 hours. Sometime yesterday afternoon until around 6AM this morning.
I rebooted several times in the evening and it did not help. They were just "on" this morning. I expect Insight server issues, again.
The direct Insight VPN (PC to Site) is still not working.
Strangely enough, OPEN VPN (PC to site) was also not working yesterday. It is working this morning.
- NathenBJun 06, 2020Apprentice
This is typically how my gear acts too, I am not using the site to site VPN, I have tried to build that a few times when we have these outages but its been a no-go. I did try the OPEN VPN setup once, when we were down for a prolonged amount of time with the same results as you. VPN to site is still down. It does look like they updated the status page to show "partial outage", so I am guessing the VPN is working for someone, somewhere.
- pwillJun 07, 2020Aspirant
Well, doesn't work for me since almost a week :-(
- tetrawestJun 07, 2020Apprentice
Back to the VPN not working.
Site-Site has been down since yesterday afternoon (Insight)
Client to Site is down (Insight)
I can get OpenVPN to work on my Android devices, but not my PCs.
We are back to "The Bad Times".
This works for a couple of weeks, then it starts to burp, hiccup and die.
- pwillJun 18, 2020Aspirant
Getting tired.
After having had issues with not seeing the VPN group at all, now everything seems normal on the insight portal. The tunnel between two BR500s is green. Clients can connect to the VPN, select the group, connect and the remote network subnets show up. Looks great. BUT, clients cannot connect to the local servers and other devices :-(. Non of the local IP's can be reached.
- rjwerth28Jul 15, 2020GuideVPN down again....
- pwillJul 16, 2020Aspirant
Fingers crossed: after support intervention I had one month of stable VPN :-)
/Patrick
- Spr1049nc03Jul 16, 2020TutorVery frustrating...
When you Really need it! - rjwerth28Jul 16, 2020Guide
Day 2 of no VPN....
- NathenBJul 16, 2020Apprentice
I had to reboot yesterday, and the VPN came back up. I just received a message from a client that they are down, and tested, they are indeed down. Tried a reboot again, no-go. Tried to restart the clients, logged out, killed the task, and the VPN task and then relaunched, no-go. Client connects, slowly, and pings are reporting a mix of time outs, transmit failed, general failure, and reply from a 10.1.7.104 showing Destination host unreachable. I have tried multiple sites, I can confirm that the VPN is down again.
Did a little more testing, I am having "sporadic" connectivity. I just ran some pings and am pinging to googles DNS at about 40 ms. When trying to ping trough the tunnel I now have some connectivity, I had 2 replies with one being 2279ms and the other being 283ms. The remaining 3 timed out.
It appeared about 20 min after my last post that things cleaned up.
- Tech123123Jul 17, 2020Aspirant
Almost 2 years of Contant VPN drops and reboots. Netgear not sure wth you thought you could accomplish by moving us to subscription base making us purchase new hardware and then bending us over so hard. But just wanted to post this as I moved my final client off of the Netgear ecosystem completely. SMH you let me down and cost me tons of money and time I will not be returning.
- eremoAug 12, 2020Guide
Insight VPN is down again for me. I was hoping the recent firmware update would help, but it hasn't worked since.
Netgear appears unable to deliver a reliable product, and unwilling to explain what the problem is.
It's just a matter of time before I replace our Netgear equipment. Anyone have recommendations for a small business VPN router?
- NathenBAug 12, 2020Apprentice
Down here as well, both Site to Site and Client to site. Not to mention that when the VPN clients connect they see the same network 6 times.
- rjwerth28Aug 14, 2020Guide
Down for 2 days now.
I hear Ubiquiti makes a very nice product.
