BSM_ENGINEERING
Dec 03, 2018Tutor
BR500 VPN Router/Firewall - 'More than one port is down(Ports disabled due to loop)'
I'm receiving Critical Alerts that my BR500 VPN Router is 'More than one port is down(Ports disabled due to loop)' and it is disconnected from my Insight Cloud Portal and Mobile Insight App. However...
MrJoshW
Jan 15, 2019NETGEAR Employee Retired
Hello,
What issues are you experiencing with the VPN on the BR500?
whatdhack
Jan 15, 2019Aspirant
I was trying to do lolipop type SSL VPN, where the WAN port and LAN ports are in the same subnet. See the follow ing architecture.
/ --- [VPN Router]
(internet) -- - [ ISP Router ] --- (LAN) -- [ Servers, hosts, etc]
Which is easily doable in Zyxel USG40/60.
