InterContinenta
Feb 14, 2020Aspirant
BR500 VPN to FVS318 site to site vpn
We just purchased a BR500 router and are trying to connect it to a FVS318. We have not been able to get the vpn connected. we are using firmware version 5.7.04 on the BR500. All of the authenticatio...
tetrawest
Feb 15, 2020Apprentice
How are you connecting? The FVS318 can't connect to the Insight System. You could do an IPSec VPN between the two, if the IPSec part of the BR500 works. I say this because the BR500 is missing the Client to LAN portion of its code.
- InterContinentaFeb 17, 2020Aspirant
Thanks. I am trying to use the IPSec part. I am having a ton of problems with it. it passes the first phase but not the second.
- tetrawestFeb 17, 2020Apprentice
I ran IPSec between two FVS336 units for many years, until NETGEAR decided to no longer support them.
I have a FVS318, but never ended up using it. I do believe the internal setup screens are similar to the FVS336
It looks like the BR500 only supports Pre-shared key and Tunnel. I would select those on the FVS318. If you are getting through Phase 1, then the PSK is working. Phase 2 sets up the tunnel.
I had the FVS336 set to "both directions" on Direction/Type. It looks like the BR500 wants this to be specific. And they need to be set opposite at each end. And make sure that both ends use "Main Mode" as it is more secure.
And make sure the PFS is on at both ends and selected the same.
Thanks. I will look at those items. I have had all FVS318's, SRX5803's etc and have had no problems with them. The BR500 is nice; however getting this VPN working has been a pain.
