sc2018
May 09, 2018Aspirant
Can I upgrade SRX5308 firmware from 3.06 to 4.21
DaneA
May 10, 2018NETGEAR Employee Retired
Hi sc2018,
Welcome to the community! :)
Yes, you can. Be reminded that the configuration file saved when using firmware v3.06 will not be applicable when you want to restore it after upgrading the firmware to v4.21 or higher. You will need to reconfigure the settings from scratch.
It would be best that you to upgrade the firmware to the latest version which is 4.3.5-3. You can download it here. Be sure to perform a factory reset after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version.
DaneA
NETGEAR Community Team
- sc2018May 10, 2018Aspirant
What I mean is I need to get the business back up, so i have a goodd cfg on the 3.06 I just want to apply the latest firmware with my current settings. I can reset at annother date and reconfigure then. Make sense?
- DaneAMay 10, 2018NETGEAR Employee Retired
Upgrading the firmware from v3.x.x (like v3.06) to v4.x.x (like v4.21 or v4.3.5-3) requires a factory reset.
I suggest you to upgrade the firmware during non-production hours (like during weekends or holidays) so that you will be able to factory reset the SRX5308 right after upgrading the firmware then reconfigure the settings from scratch.
DaneA
NETGEAR Community Team - DaneAMay 14, 2018NETGEAR Employee Retired
I just want to follow-up on this. Were you able to upgrade the firmware of the SRX5308 to the latest v4.3.5-3 then perform a factory reset and configure the settings from scratch?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- sc2018May 18, 2018Aspirant
I plan to do this over the next 2 days. I still do not see why I cannot just upgrade the firmware and move on. The factory reset seems like a waste.
