sc2018
May 09, 2018Aspirant
Can I upgrade SRX5308 firmware from 3.06 to 4.21
sc2018
May 10, 2018Aspirant
What I mean is I need to get the business back up, so i have a goodd cfg on the 3.06 I just want to apply the latest firmware with my current settings. I can reset at annother date and reconfigure then. Make sense?
DaneA
May 10, 2018NETGEAR Employee Retired
Upgrading the firmware from v3.x.x (like v3.06) to v4.x.x (like v4.21 or v4.3.5-3) requires a factory reset.
I suggest you to upgrade the firmware during non-production hours (like during weekends or holidays) so that you will be able to factory reset the SRX5308 right after upgrading the firmware then reconfigure the settings from scratch.
DaneA
NETGEAR Community Team
