Suryashekhardas
Nov 23, 2017Follower
Can you use a Netgear ProSafe VPN Firewall as a regular switch?
Hello! I would like to purchase a used NETGEAR FVS336G-300 V3 here in my country and i am getting it for really cheap from a friend, around 35 USD. It also has two gigabit ports from what it looks l...
- Nov 26, 2017
Hi Suryashekhardas,
Welcome to the community! :)
If you will use the FVS336Gv3 as a plain unmanaged switch, do the following:
1. Assign a static LAN IP Address to the FVS336Gv3 that is within the same IP range of your existing local area network.
2. Disable the DHCP server.
2. Connect your existing Xiaomi router to one of the 4 LAN ports of the FVS336Gv3 and use the other 3 LAN ports to connect other networking devices such as PC/s, printers, etc. Take note that you will NOT use the two WAN ports of it.
If I will choose between the FVS336Gv3 (as a switch) and the GS108E, I will select the GS108E because you can configure certain Layer 2 settings such as VLAN and Port Mirroring. The latest model of the GS108E switch is the GS108Ev3 switch. For more information about the GS108Ev3, kindly access and read the links below:
If you are just looking for a plain, unmanaged, pass-through switch that will extend your local network giving you additional ports to connect more networking devices, I suggest you the GS108v4 switch. Kindly check its specifications on the link below:
DaneA
NETGEAR Community Team
DaneA
Nov 26, 2017NETGEAR Employee Retired
Hi Suryashekhardas,
DaneA
DaneA
Nov 29, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
