just_me2
Oct 24, 2016Aspirant
Can't access remote LAN through VPN
Hi, I've got a problem with VPN configuration as L2TP (yes, I saw manual, it seems to be easy-to-go but it not works ;-) I've configured L2TP VPN, add user - after restart router configuration seem...
just_me2
Oct 28, 2016Aspirant
No - this instruction didn't help.
I've used them before I had written this topic.
I did everything exactly like in this instruction (of course using my subnet parameters). Previously I've deleted all configuration I've made before starting configuration again.
I can connect to VPN, open admin panel of my router but I have no access to remote lan :-(
- DaneAOct 30, 2016NETGEAR Employee Retired
Hi just_me2,
Here are my follow-up questions:
a. Is the FVS336Gv3 behind another firewall router?
b. How is everything connected? Kindly post an image or screenshot of your detailed network setup.
c. Is L2TP have a check mark under VPN Pass through? To verify, go to Security > Firewall > Attack Checks on the web-GUI of the FVS336Gv3. Kindly check the image below as reference:
DaneA
NETGEAR Communtiy Team
