just_me2
Oct 24, 2016Aspirant
Can't access remote LAN through VPN
Hi, I've got a problem with VPN configuration as L2TP (yes, I saw manual, it seems to be easy-to-go but it not works ;-) I've configured L2TP VPN, add user - after restart router configuration seem...
just_me2
Oct 30, 2016Aspirant
Hi,
Thanks for reply!
About your questions:
a) no - fvs336g is connected directly to WAN
b) I've connected both WAN's (as load balancing). One LAN is connected to switch 24-port (without DMZ).
c) Yes - vpn-pass through is marked as enabled.
Config is exactly like in tutorial (only one modification is local network address/netmask but it's obvious I think :-)))))).
is there any way to restore/delete all vpn options to default without restoring whole router options to default?
I've upgraded firmware to 4.3.4-2
I've noticed few things:
a) In my opinion connection takes a little bit too long time and often disconnects without any reason.
b) After connection is established only ONE ping goes to target host in remote LAN - others are marked as "timeout". Why only ONE packet is redirected to target host in remote LAN?
Please help! I've no idea why it doesn't work!
VPN logs will be helpful?
