just_me2
Oct 24, 2016Aspirant
Can't access remote LAN through VPN
Hi, I've got a problem with VPN configuration as L2TP (yes, I saw manual, it seems to be easy-to-go but it not works ;-) I've configured L2TP VPN, add user - after restart router configuration seem...
just_me2
Oct 30, 2016Aspirant
I've changed Identifier Type (in IKE Policy -> section Local) from FQDN to Local WAN IP and I've tried to connect using virtual machine (win7 installed on Oracle VirtualBox) - as act of total desperation.... :-)))) Miracle! It WORKS! But......
I've damn Windows 10 and still I can't connect to VPN. Configuration is exactly like in virtual machine Win7 but it doesn't work.
Problem is in vpn client built in Win10 I think.
EDIT: Connection from Win 7 works randomly - one conenction works perfect (fast connection, access to remote LAN).
Few minutes later connection takes a long time, with error 809. When I'm finally connected to VPN I can ping to router using tunnel IP but I've no access to remote LAN.
