robert5150
Jan 18, 2013Aspirant
Classical Routing - Assistance needed
I am trying to get routing mode (Note: not NAT mode) working through my Netgear Firewall. It's an FVS336G v2. I have the following CIDR Block and IP Address from my ISP - COX. My block is as follo...
robert5150
Jan 20, 2013Aspirant
fordem wrote: With the router configured for classic routing, can you ping the following from the laptop...
a) 68.xxx.xxx.65
b) 57.224.xxx.100
c) 57.224.xxx.97
I can ping my 68.xxx.xxx.65 network just fine (same one my laptop is on). And i can ping the the "WAN Side" of my firewall .100 however i cannot ping my WAN Sides Gateway .97 (from my laptop)
Also from the diagnostics page op the netgear i can ping all IPs as requested without issue it only seems to be ping from my "LAN" side (the customer address) where i have the problem.
If i ping 4.2.2.1 (From the LAN Side of the firewall) I see that the packet leaves the network (request) but never receives a reply.
I cant tell if the breakdown is on my side or the providers side. I am still not sure if i need to add routes here but i dont think i do as both networks are physically connected the networks in question.
