robert5150
Jan 18, 2013Aspirant
Classical Routing - Assistance needed
I am trying to get routing mode (Note: not NAT mode) working through my Netgear Firewall. It's an FVS336G v2. I have the following CIDR Block and IP Address from my ISP - COX. My block is as follo...
fordem
Jan 20, 2013Mentor
You should not need to add a static route for the 57.224 network because it is directly connected to the network, and you should be able to ping anything there from both the router & the laptop.
Can you PM me the full addresses that Cox gave you for the 57.224 network?
