robert5150
Jan 18, 2013Aspirant
Classical Routing - Assistance needed
I am trying to get routing mode (Note: not NAT mode) working through my Netgear Firewall. It's an FVS336G v2. I have the following CIDR Block and IP Address from my ISP - COX. My block is as follo...
robert5150
Jan 20, 2013Aspirant
fordem wrote: You should not need to add a static route for the 57.224 network because it is directly connected to the network, and you should be able to ping anything there from both the router & the laptop.
Can you PM me the full addresses that Cox gave you for the 57.224 network?
Ok so based on my description and i can provide IPs in a PM if needed. This should be working as my IPs are basicallyt transparent correct?
That is am i supposed to NAT eventhough i have a routed CIDR block? Or is that not a requirement beucase i i have my own block?
I just want to be very clear on this and normally i dont do this type of Advanced networking.
