robert5150
Jan 18, 2013Aspirant
Classical Routing - Assistance needed
I am trying to get routing mode (Note: not NAT mode) working through my Netgear Firewall. It's an FVS336G v2. I have the following CIDR Block and IP Address from my ISP - COX. My block is as follo...
fordem
Jan 20, 2013Mentor
Never mind about the ip addresses - I'm starting to think the gateway on the ISP side (57.224.xxx.97 maybe incorrectly configured.
When pinged from the router itself it responds, because it is being pinged from a host on a network that is directly attached, but when pinged within from your network it does not know where to send the reply (back to your router) and maybe sending it forward to it's own default gateway.
Do you have the facilities to connect a sniffer to the WAN interface of the FVS336G? Either a network tap or an old hub (if you can find one) and a laptop running wireshark would let you see the traffic to confirm if the gateway at .97 is responding.
