tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
tachyon_pulse
Feb 01, 2015Aspirant
One question I have regards the check box for :Enable Inter VLAN Routing". When it is checked does it immediately open that VLAN to all the other VLANs or does it just allow you to configure individual routes to that VLAN? Also, for it to work, does it have to be set on both the VLAN you want to access and the one you're accessing it from? Sorry if this is a dumb question, but I'm trying to understand any odd details.
