tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
fordem
Feb 02, 2015Mentor
SamirD wrote: It just dawned on me--why not create a 5th vlan and put your 'Internet of things' in there? Then you can simply allow intervlan communication between all the other the vlans you want.
Have you tried to control access between VLANs - based on my looking at the interface and my discussions with tech support, once you enable interVLAN routing you have no further control.
It MAY be possible to disable interVLAN routing on a specific VLAN, but I have not tested this. I do have a new 318N still in shrinkwrap I'll break out when I have the time, but that's not going to happen this week.
On the other hand - you CAN set DMZ/LAN rules - so it should be possible to prevent access from the IOT on a DMZ to any or all of the VLANs.
