tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
SamirD
Feb 02, 2015Prodigy
So in this example, everything on vlan1,2,4 will see each other. Vlans 2 and 4 will have full access to each other.
tachyon_pulse wrote: Ok, so this is something I wasn't clear on; for interVLAN routing to work, does it have to be enabled on each of the VLANs that will talk to each other? For instance, if I have:
VLAN1 - interVLAN routing = ENABLED
VLAN2 - interVLAN routing = ENABLED
VLAN3 - interVLAN routing = DISABLED
VLAN4 - interVLAN routing = ENABLED
Does this allow interVLAN sharing of devices on VLAN1 with VLANS2 & 4 but not to VLAN3 and do I still need to set up static routes to the specific devices once enabled or is that implicit when you enable interVLAN routing. Also in doing this is there's no way block traffic between VLANs 2 & 4?
Which devices are you referring to for static routes? What vlan are they on?
