tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
fordem
Feb 02, 2015Mentor
tachyon_pulse wrote: Does this allow interVLAN sharing of devices on VLAN1 with VLANS2 & 4 but not to VLAN3 and do I still need to set up static routes to the specific devices once enabled or is that implicit when you enable interVLAN routing. Also in doing this is there's no way block traffic between VLANs 2 & 4?
I have not attempted interVLAN routing with more than two VLANs, so I can't comment on that, but SamirD seems to be saying that you can exclude a single VLAN.
No static routes will be necessary to permit interVLAN routing as the router will automatically configure the routes required for the directly connected networks, and there is presently no way to block/permit specific traffic between the VLANs 2 & 4
