tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
tachyon_pulse
Feb 02, 2015Aspirant
Ok, thank you both. For interVLAN routing to work, you must enable it on all the VLANs you want to be able to pass data between. Checking it on a single one does nothing for you (is that correct?)
In another forum I was told that the FVS318N was limited as far as how you can configure (for my needs) and recommended a ZyWALL USG40W-NB and a managed switch with 'private vlan' or 'guest vlan' feature to support my requirement of isolating my wired 'IoT' devices.
Is there similar Netgear equipment?
