tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
SamirD
Feb 02, 2015Prodigy
Yep, you can. I checked my own 318N Web UI before posting. ;)
fordem wrote: ...but SamirD seems to be saying that you can exclude a single VLAN.
Yes, checking on a single vlan does nothing. I think it is checked by default because I found it checked on my default vlan even though I don't have it checked on any other vlans.
tachyon_pulse wrote: Ok, thank you both. For interVLAN routing to work, you must enable it on all the VLANs you want to be able to pass data between. Checking it on a single one does nothing for you (is that correct?)
In another forum I was told that the FVS318N was limited as far as how you can configure (for my needs) and recommended a ZyWALL USG40W-NB and a managed switch with 'private vlan' or 'guest vlan' feature to support my requirement of isolating my wired 'IoT' devices.
Is there similar Netgear equipment?
The 318N is quite powerful in it's ability to limit it's attached devices from seeing each other. I'm not sure what your physical wiring is to your IOT devices, but a setting a vlan to a particular port and putting only those devices on that port coupled with disabling intervlan should give you the isolation that you want. I've used that several times for internal testing.
