tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
tachyon_pulse
Feb 02, 2015Aspirant
Hi Samir, so that's the bugger, client isolation is only for a VLAN's wireless clients, that is wireless clients can't see each other, but they can see wired clients on the same VLAN and the hardwired clients can 'see' everything. I don't understand why there isn't a simple check-box equivalent for wired clients (or simply all clients on a particular VLAN.
Since I already have the 318N, it would be nice to find a Netgear managed switch that would integrate with the 318N for my isolation needs. Once I get this all set up I plan to do some tests to see if it behaves as I need. Any specific gear recommendations would be appreciated if not, please tell me explicitly the features I need to look for. Thanks. This is an awesome lesson.
