tachyon_pulse
Jan 27, 2015Aspirant
Configuring static route
Device: FVS318N - Prosafe Wireless N VPN Firewall Firmware Version : 4.3.1-22 I'm having problems getting a static route configured. I am logged into the router from 192.168.2.100 and from the...
tachyon_pulse
Feb 10, 2015Aspirant
SamirD, Thanks for the tip on the used gear, any preference on which is friendlier to configure and use for a networking newbie? I picked up an inexpensive TL-SG108E and by using it's MTU VLAN configuration I was able to achieve the wired client isolation I wanted. I now have 2 final challenges.
1 On 192.168.3.0/24 subnet that has the gateway and WiFi on the NetGear router, When I do a network scan from my iPhone, the "WLAN Partition" feature hides all the WiFi devices connected to that SSID, it doesn't hide any of the wired devices connected to the SG108E. Is there a way to hide the wired addresses from the WLAN addresses on the same subnet?
2. I have an Amazon FireStick in my 192.168.3.0/24 WiFi segment, I wanted to take an old iPod and install the Amazon Fire app on it to control the FireStick. This requires that they both be on the same subnet and and can see each other. I'm wondering if their is some way (e.g., static route) that would maintain the WLAN isolation but let the iPod communicate with the FireStick?
Thanks for all your advice and mentoring. I'm learning a lot.
